Change the Default Username
You can change usernames for default users (rwa, rw, and ro) for the specified access level. You cannot change usernames for user-defined users.
Only the rwa user can change the default username.
Perform this procedure to change the default username for the specified access level.
Change the default username:
Switch:1>enable Switch:1#config t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#username EXUser ? level Which access level Switch:1(config)#username EXUser level ? l1 Change Layer 1 read write enable password l2 Change Layer 2 read write enable password l3 Change Layer 3 read write enable password ro Change read only enable password rw Change read write enable password rwa Change read write all enable password Switch:1(config)#username EXUser level ro Do you want to change username for the default RO user ? (y/n) ? y Enter the old password : ** Enter the New password : ***** Re-enter the New password : *****
The following table defines parameters for the username command.
| Variable | Value |
                             WORD<1-20>  |
                             Specifies the user logon name.  |
                             level l1|l2|l3|ro|rw|rwa  |
                             Specifies the access level.  |
