Use this procedure to configure the RADIUS server reachability settings.
 - Click RADIUS.
 - Click the RADIUS Global tab.
 - In RadiusReachability, select either useStatusServerPackets or useDummyRadiusRequests.
 - In the UserName field, type the reachability user name.
 - In the Password field, type the reachability password.
 - In the Confirm Password field, retype the reachability password.
 - In the Unreachable Timer field, type the interval in seconds between checks when the RADIUS server is unreachable.
 - In the KeepAlive Timer field, type the interval in seconds between checks when the RADIUS server is reachable.
 - Click the Apply.
RADIUS Global Field Descriptions
Use the data in the following table to use the RADIUS Global tab.
                                 Name  |
                                 Description  |
                                 Enable  |
                                 Enables the RADIUS authentication feature globally.  |
                                 MaxNumberServer  |
                                 Specifies the maximum number of servers to be used, between 1 and 10, inclusive.  |
                                 AccessPriorityAttrValue  |
                                 Specific to RADIUS authentication. Specifies the vendor-specific attribute value of the access-priority attribute to match the type value set in the dictionary file on the RADIUS server. The valid values are 192 through 240. The default is 192.  |
                                 AcctEnable  |
                                 Enables RADIUS accounting.  |
                                 AcctAttriValue  |
                                 Specific to RADIUS accounting. Specifies the vendor-specific attribute value of the CLI-command attribute to match the type value set in the dictionary file on the RADIUS server. This value must be different from the access-priority attribute value configured for authentication. The valid values are 192 through 240. The default value is 193.  |
                                 AcctIncludeCli  |
                                 Specifies whether you want CLI commands included in RADIUS accounting requests.  |
                                 ClearStat  |
                                 Clears RADIUS statistics from the device.  |
                                 McastAttributeValue  |
                                 Specifies the value of the Mcast attribute. The valid values are 0 through 255. The default value is 90.  |
                                 AuthInfoAttrValue  |
                                 Specifies the value of the authentication information attribute. The valid values are 0 through 255. The default value is 91.  |
                                 CommandAccessAttrValue  |
                                 Specifies the value of the command access attribute. The valid values are 192 through 240. The default value is 194.  |
                                 CliCommandAttrValue  |
                                 Specifies the value of the CLI command attribute. The valid values are 192 through 240. The default value is 195.  |
                                 AuthInvalidServerAddress  |
                                 Displays the number of access responses from unknown or invalid RADIUS servers.  |
                                 SourceIpFlag Note:
                            Exception: only supported on VSP 8600 Series.  |
                                 Includes a configured IP address as the source address in RADIUS packets. The default is false. RADIUS supports IPv4 and IPv6 addresses with no difference in functionality or configuration.  |
                                 CliCmdCount  |
                                 Gives the value for the CLI command count. Specify an integer from 1 to 40. The default is 40.  |
                                 CliProfEnable  |
                                 Enables RADIUS CLI profiling.  |
                                 SupportedVendorIds  |
                                 Shows the vendor IDs that the software supports for RADIUS.  |
                                 RadiusReachability  |
                                 Specifies the mode for RADIUS reachability. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode.  |
                                 SecureEnable  |
                                 Enable RADIUS Security (RADSec).  |
                                 UserName  |
                                 Specifies the username for RADIUS server reachability. The default is extremenetworks.  |
                                 Password  |
                                 Specifies the password for RADIUS server reachability. The default is extremenetworks.  |
                                 Confirm Password  |
                                 Confirms the password for RADIUS server reachability.  |
                                 Unreachable Timer  |
                                 Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds.  |
                                 Keep Alive Timer  |
                                 Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds.  |
