Add a RADIUS server to allow RADIUS service on the switch.
Remote Dial-In User Services (RADIUS) supports both IPv4 and IPv6 addresses, with no differences in functionality or configuration in all but the following case. When adding a RADIUS server or updating a RADIUS server in Enterprise Device Manager (EDM) you must specify if the address type is an IPv4 or an IPv6 address.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select RADIUS.
  3. Select the RADIUS Servers tab.
  4. Select Insert.
  5. Configure the server as required.
  6. Select Insert.
RADIUS Servers Field Descriptions
Use the data in the following table to use the RADIUS Servers tab.
Name
Description
AddressType
Specifies either an IPv4 or an IPv6 address. RADIUS supports IPv4 and IPv6 addresses.
Address
Specifies the IP address of the RADIUS server. RADIUS supports IPv4 and IPv6 addresses.
UsedBy
Configures how the server functions:
  • cli—configure the server for CLI authentication.
  • eapol—configure the server for EAPoL authentication.
  • endpointTracking—configure the server for Endpoint Tracking authentication.
  • snmp—configure the server for SNMP accounting.
  • web—configure the server for HTTP(s) authentication.
The default is cli.
Priority
Specifies the priority of each server, or the order of servers to send authentication. The default is 10.
TimeOut
Specifies the time interval in seconds before the client retransmits the packet. The default is 8.
Enable
Enables or disables authentication on the server. The default is true.
MaxRetries
Specifies the maximum number of retransmissions allowed. The default is 1.
UdpPort
Specifies the UDP port that the client uses to send requests to the server. The default value is 1812.
The UDP port value set for the client must match the UDP value set for the RADIUS server.
SecretKey
Specifies the RADIUS server secret key, which is the password used by the client to be validated by the server.
AcctEnable
Enables or disable RADIUS accounting. The default is true.
AcctUdpPort
Specifies the UDP port of the RADIUS accounting server. The default value is 1813.
The UDP port value configured for the client must match the UDP value configured for the RADIUS server.
SecureEnable
Note:
Exception: not supported on VSP 8600 Series.
Enable RADIUS Security (RADSec).
SecureMode
Note:
Specifies the RADSec security mode. Possible values are:
  • tls - Transport Layer Security (TLS) encryption over Transmission Control Protocol (TCP)
  • dtls - Datagram Transport Layer Security (DTLS) encryption over User Datagram Protocol (UDP)
The default is tls.
SecureProfile
Note:
Specifies the name of the secure profile.
SecureLogLevel
Note:
Specifies the log severity level. Possible values are :
  • critical
  • error
  • warning
  • info
  • debug
SourceIpAddr
Specifies the IP address to use as the source address in RADIUS packets. To use this option, you must set the global RADIUS SourceIpFlag to true. RADIUS supports IPv4 and IPv6 addresses.
