Table 1. FDB Protected by Port product support
Feature
Product
Release introduced
FDB protected by port (MAC security limit-learning)
VSP 4450 Series
VSP 4000 4.0
VSP 4900 Series
VOSS 8.3
VSP 7200 Series
Not Supported
VSP 7400 Series
Not Supported
VSP 8200 Series
Not Supported
VSP 8400 Series
Not Supported
VSP 8600 Series
Not Supported
XA1400 Series
Not Supported
To perform MAC-layer bridging, the device must know the destination MAC-layer address of each device on each attached network to forward packets to the appropriate destination. The system stores MAC-layer addresses in the bridge forwarding database (FDB) table, and can forward packet traffic based on the destination MAC-layer address information.
MAC security
Use MAC security to control traffic from specific number of MAC addresses. You can also limit the number of allowed MAC addresses. You can enable this feature at the port level.
Port-level security applies to traffic for all VLANs received on that port.
Port-level MAC security provides limit—learning option:
The following list identifies restrictions to MAC security limit-learning:
