Configure an IS-IS accept policy for a specific I-SID list to represent local or remote Layer 3 VSNs, which allows the system to redistribute the remote VSNs to the VSN where you applied the filter.
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map to apply.
 - Click IS-IS.
 - Click the Accept Isid-List tab.
 - Click Insert.
 - In the Name field, specify the I-SID list name.
 - Select enable in the Enable check box to enable the filter.
 - In the PolicyName field, specify the route-map name.
 - Click Insert.
Accept Isid–List field descriptions
Use the data in the following table to configure Accept Isid-List tab.
 Name  |
 Description  |
 Name  |
 Specifies the name of I-SID list.  |
 Enable  |
 Enables or disables the I-SID list entry. The value must be enabled to filter. The default is disabled.  |
 PolicyName  |
 Specifies the route policy name.  |
 BackBonePolicyName  |
 Specifies the backbone route policy name.  |
