DEMO FEATURE - Read Only User for EDM is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see VOSS Feature Support Matrix.
Enable the web management interface to provide management access to the switch using a web browser.
HTTP and HTTPS, and FTP support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Important
Important
To enable HTTP access to the device, you must disable the web server secure-only option. To enable HTTPS access to the device, the web server secure-only option is enabled by default. The TFTP server supports both IPv4 and IPv6 TFTP clients.
    enable
    configure terminal
  2. Enable the web server:
    web-server enable
  3. To enable the secure-only option (for HTTPS access), enter:
    web-server secure-only
  4. Optional: To disable the secure-only option (for HTTP access), enter:
    no web-server secure-only
  5. Configure the username and the access password:
    web-server password rwa WORD<1–20>
    Important
    Important
    The default passwords and community strings are documented and well known. Change the default passwords and community strings immediately after you first log on.
  6. Enter and confirm your password.
  7. Enable read-only user:
    web-server read-only-user enable
  8. Save the configuration:
    save config
  9. Display the web server status:
    show web-server
Enable the secure-only web-server.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#web-server enable
Switch:1(config)#web-server secure-only
Switch:1(config)#web-server read-only-user enable
Switch:1(config)#web-server password rwa smith2
Enter the New password : ********
Re-enter the New password : ********
Password changed.
Switch:1(config)#web-server password ro jones6
Password changed.
Switch:1(config)#show web-server
Web Server Info :
        Status                    : off
        Secure-only               : enabled
        TLS-minimum-version       : tlsv12
        RO Username Status        : disabled
        RO Username               : user
        RO Password               : ********
        RWA Username              : admin
        RWA Password              : ********
        Def-display-rows          : 30
        Inactivity timeout        : 900 sec
        Html help tftp source-dir :
        HttpPort                  : 80
        HttpsPort                 : 443
        NumHits                   : 0
        NumAccessChecks           : 0
        NumAccessBlocks           : 0
        NumRxErrors               : 0
        NumTxErrors               : 0
        NumSetRequest             : 0
        Minimum password length   : 8
        Last Host Access Blocked  : 0.0.0.0
        In use certificate        : Self signed
        Certificate Truspoint CA Name :
        Certificate with Subject Name : 823
        Ciphers-Tls               : TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
                                    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
                                    TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 TLS_DHE_RSA_WITH_AES_256_CBC_SHA
                                    TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 TLS_DHE_RSA_WITH_AES_128_CBC_SHA
                                    TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA
                                    TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_128_CBC_SHA
Use the data in the following table to use the web-server command.
Variable
Value
def-display-rows <10-100>
Configures the number of rows each page displays, between 10 and 100.
enable
Enables the web interface. To disable the web server, use the no form of this command:
no web-server [enable]
help-tftp <WORD/0-256>
Configures the TFTP or FTP directory for Help files, in one of the following formats: a.b.c.d:/| peer:/ [<dir>]. The path can use 0–256 characters. The following example paths illustrate the correct format:
  • 192.0.2.1:/help
  • 192.0.2.1:/
http-port <80-49151>
Configures the web server HTTP port. The default port is 80.
 https-port <443-49151>
Configure the web server HTTPS port. The default port is 443.
inactivity-timeout<30–65535>
Configures the web-server session inactivity timeout. The default is 900 seconds (15 minutes).
password {ro | rwa} WORD<1-20>
Configures the logon and password for the web interface.
password min-passwd-len<1–32>
Configures the minimum password length. By default, the minimum password length is 8 characters.
read-only-user
Enables read-only user for the web server.
Note:
read-only-user enable is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix.
secure-only
Enables secure-only access for the web server.
tls-min-ver<tlsv10|tlsv11|tlsv12>
Configures the minimum version of the TLS protocol supported by the web-server. You can select among the following:
  • tlsv10 – Configures the version to TLS 1.0.
    Note:
    tlsv10 is not supported in enhanced secure mode.
  • tlsv11 – Configures the version to TLS 1.1.
  • tlsv12 – Configures the version to TLS 1.2
The default is tlsv12.
