Configure port lock to administratively lock a port or ports to prevent other users from changing port parameters or modifying port action. You cannot modify a locked port until you unlock the port.
Switch:1> enable
Switch:1# configure terminal
Log on to GigabitEthernet Interface Configuration mode:
Switch:1(config)# interface GigabitEthernet 1/1
Unlock port 1/14:
Switch:1(config-if)# no lock port 1/14 enable
The following table defines parameters for the interface gigabitethernet and lock port commands.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. For the lock port command, use the no form of this command to unlock a port: no lock port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
