Configure a static foreign source on the global router. Configuration is done at the Controller.
 - Click SPB-PIM-GW.
 - Click the Controller-Foreign-Source tab.
 - Click Insert.
 - In the SourceAddress box, type the multicast foreign source IP address.
 - In the GroupAddress box, type the group IP address.
 - Click Insert.
Controller-Foreign-Source field descriptions
Use the data in the following table to use the Controller-Foreign-Source tab.
 Name  |
 Description  |
 SourceAddress  |
 Specifies the source IP address from a foreign multicast domain.  |
 GroupAddress  |
 Specifies the multicast group IP address associated with the foreign source.  |
 GatewaySysId  |
 Displays the system ID of the node selected as the Gateway for this foreign source. GatewaySysId field will have a valid value if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is 0.  |
 GatewayHostName  |
 Displays the host name of the node selected as the Gateway for this foreign source. GatewayHostName field will have valid values if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is NULL.  |
 Type  |
 Displays the owner type for this source.  |
 Owner  |
 Displays the IP address of the MSDP peer if the foreign source is MSDP.  |
