Display information about the files on a USB device to view general file information.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select File System.
  3. Select the USB Files tab.
USB Files field descriptions
Use the data in the following table to use the USB Files tab.
Name
Description
Slot
Specifies the slot number of the device.
Name
Specifies the directory name of the file.
Date
Specifies the creation or modification date of the file.
Size
Specifies the size of the file.
