Configure additional routers as candidate BSRs (C-BSR) to provide backup protection in the event that the primary BSR fails. PIM-SM cannot run without a BSR.
Static RP is disabled.
The C-BSR with the highest configured preference becomes the BSR for the domain. If two C-BSRs use equal preference, the candidate with the higher IP address becomes the BSR. If you add a new C-BSR with a higher preference to the domain, it automatically becomes the new BSR.
Configure a candidate BSR:
Switch:1(config-if)#ip pim bsr-candidate preference 2
Variable definitions
Use the definitions in the following table to use the ip pim bsr-candidate command.
 Variable  |
 Value  |
 preference <0–255>  |
 Activates the C-BSR on this interface and configures its preference value, from 0–255, to become a BSR. The C-BSR with the highest BSR preference and address is the preferred BSR. The default is –1, which indicates that the current interface is not a C-BSR. To set this option to the default value, use the default operator with the command.  |
