This procedure only applies to VSP 8400 Series.
- In the Device Physical View, select the port or ports for which to display MKA statistics.
 - Select General.
 - Select the MACsec MKA Stats tab.
 - Optional: Select Clear Stats to clear MKA MACsec statistics for the selected port or ports. Clearing MKA MACsec statistics can be useful for debugging purposes.
MACsec MKA Stats Field Descriptions
Use the data in the following table to use the MACsec MKA Stats tab.
| Name | Description |
                                 MKPDUValidatedPkts  |
                                 Specifies the number of MKPDU packets received and validated.  |
                                 RxDistributedSAKPkts  |
                                 Specifies the number of SAK packets received.  |
                                 MKPDUTransmittedPkts  |
                                 Specifies the number of MKPDU packets transmitted.  |
                                 TxDistributedSAKPkts  |
                                 Specifies the number of SAK packets transmitted.  |
