By default, the RESTCONF server uses HTTP. If you need to use HTTPS, generate a certificate file and transfer the certificate file to the /intflash directory on the switch.
For more information on generating certificate files, see Manage an SSL Certificate.
Ensure that you have the certificate file in the /intflash directory on the switch.
Switch:1>enable Switch:1# configure terminal Enter configuration commands, one per line. End with CTRL/Z. Switch:1(config)#application Switch:1(config-app)#no restconf enable Switch:1(config-app)#restconf install-cert-file /intflash/.cert/restconf-cert.pem Switch:1(config-app)#restconf tls Switch:1(config-app)#restconf enable
The following table defines parameters for the restconf command.
                             Variable  |
                             Value  |
                             enable  |
                             Enables the RESTCONF Server.  |
                             install-cert-file WORD<1-128>  |
                             Installs the certificate file for the RESTCONF server.  |
                             tcp-port <1-49151>  |
                             Set RESTCONF Server TCP port number.  |
                             tls  |
                             Enables TLS for the RESTCONF server. The default is disabled.  |
                             trap-notification  |
                             Enables trap notification.  |
