 - Select IKE.
 - Select Globals tab.
 - In the CertIdentitySubjectName field, enter the digital certificate subject name use as identity certificate.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
| Name | Description |
                             CertIdentitySubjectName  |
                             Specifies the digital certificate subject name use as identity certificate in IKE.  |
