            Perform this task to run a VM command from EDM. To include spaces in the syntax,
                include the text string in quotation marks (").
                In the navigation pane, expand .
                Select the Virtual Service.
                Select the Globals
                    tab.
                In the ScalarsName
                    field, type a virtual service name.
                In the ExecuteCommand
                    field, type the ls command for the VM configs directory.
                    For example, "ls /home/rwa/configs".
                In the FigwCli field,
                    type a command to send it to the Fabric IPsec Gateway. For more information about
                        Fabric IPsec Gateway commands, see VOSS CLI Commands Reference.
                Select Apply.
