Display dampened path information to see which routes are suppressed.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
The VRF must have an RP trigger of BGP.
Enable dampened routes.
 - Select BGP.
 - Select the Dampened Routes tab.
Dampened Routes field descriptions
Use the data in the following table to use the Dampened Routes tab.
 Name  |
 Description  |
 IpAddrPrefix  |
 Specifies the IP address prefix in the NLRI field. This variable is an IP address that contains the prefix with a length specified by IpAddrPrefixLen. Bits beyond the length specified by IpAddrPrefixLen are set to zero.  |
 IpAddrPrefixLen  |
 Specifies the length, in bits, of the IP address prefix in the NLRI field.  |
 Peer  |
 Specifies the IP address of the peer from which the router learns the path information.  |
 FlapPenalty  |
 Specifies the penalty based on number of route flaps.  |
 FlapCount  |
 Specifies the number of times a route flapped (went down and up) since the last time the penalty was reset to zero.  |
 RouteDampened  |
 Indicates whether this route is suppressed or announced.  |
 ReuseTime  |
 Specifies the system-configured time for route reuse.  |
