Use the data in the following table to use the StaticIsidIpMcastRoutes tab.
                                 Name  |
                                 Descriptions  |
                                 IsidType  |
                                 Indicates the type of static data I-SID.  |
                                 Group  |
                                 Indicates the group address of the IP multicast route that contains multicast routing information.  |
                                 Source  |
                                 Indicates the IP address where the IP multicast route originated.  |
                                 VsnIsid  |
                                 Indicates the Virtual Routing Network (VSN) I-SID.  |
                                 SourceBeb  |
                                 Indicates the name of the source Backbone Edge Bridge for IP multicast route.  |
                                 VrfName  |
                                 Indicates the VRF name of the interface.  |
                                 DataIsid  |
                                 Indicates the static I-SID value for IP multicast route.  |
                                 Bvlan  |
                                 Indicates the Backbone VLANs (B-VLANs) for the IP multicast route.  |
                                 NniInterfaces  |
                                 Specifies the NNI ports for the IP multicast route.SPBM runs in the core on the ports that connect to the core. These ports are NNI ports. Ports that face a customer VLAN are user-to-network interface (UNI) ports.  |
