Use the following procedure to enable VRRP notification control. The generation of SNMP traps for VRRP events is enabled, by default.
You can configure traps by creating SNMPv3 trap notifications, creating a target address to send the notifications, and specify target parameters. For more information about how to configure trap notifications, see Logs and Traps.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrrp Switch:1(config-vrrp)#send-trap enable vrf mgmtrouter Switch:1(config)#show ip vrrp vrf mgmtrouter ===================================== VRRP Global Settings - VRF mgmtrouter ===================================== ping-virtual-address : enabled send-trap : enabled
Variable definitions
Use the data in the following table to use the send-trap and show ip vrrp commands.
 Variable  |
 Value  |
 enable  |
 Enables generation of SNMP traps.  |
 vrf WORD<1–16>  |
 Configures the send-trap for a particular VRF.  |
