View multicast interface information to verify the multicast configuration.
This tab shows multicast routing information specific to interfaces.
You can view multicast interface information for a Layer 3 VSN the same way you view the Global Router except that you must first launch the appropriate VRF context.
This procedure is supported on a DvR Controller; it is not supported on a DvR Leaf node.
 - Select Multicast.
 - Select the Interfaces tab.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
 Name  |
 Description  |
 Interface  |
 Displays the slot and port number or VLAN ID for this entry.  |
 Ttl  |
 Displays the datagram time-to-live (TTL) threshold for the interface. IP multicast datagrams with a TTL less than this threshold are not forwarded out of the interface. The default value of 0 means that all multicast packets are forwarded out of the interface.  |
 Protocol  |
 Displays the protocol as one of the following:
