The VSP 7200 Series hardware models are available with twenty four 1/10 GbE SFP/SFP+ and four 40 GbE QSFP+ ports enabled by default. You must purchase a Port License to enable the remaining ports on the switch. You can use the Port License alone or combined with a Premier License or Premier License with MACsec at any time. When combining these licenses, the old license file must be deleted and the new license file that has the combination of Port and Premier or Premier with MACsec must be installed and loaded on the switch.
See Feature Licensing for VSP 4450 Series, VSP 4900 Series, VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series for more information about Premier License features.
The Port License order code is 386914.
Port Licenses are not available with Trial Licenses.
On a VSP 7200 Series switch that is port licensed, use the command show interfaces gigabitethernet to view the licensed status of the ports on the switch.
The following example shows the partial output of the show interfaces gigabitethernet command for the VSP 7254XSQ switch. View the LICENSE STATUS field. It can have one of the following values:
n/a: Indicates that it is not a port that is activated by a port license.
locked: Indicates that the port is locked and non-operational because the switch is port licensed and a valid port license is not present.
Attempting to enable a locked port, for example port 1/25, displays the error message Error: port 1/25, Port License is required to enable this port.
unlocked: Indicates that the port is unlocked and is operational, because a valid port license is present.
Switch:1#show interfaces gigabitEthernet
                                          Port Interface
PORT                        LINK  PORT           PHYSICAL          STATUS         LICENSE
NUM      INDEX DESCRIPTION  TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE STATUS
1/1      192   10GbNone         true  false    1950  a4:25:1b:54:9c:00 up     down    n/a
1/2      193   10GbNone         true  false    1950  a4:25:1b:54:9c:01 down   down    n/a
1/3      194   10GbNone         true  false    1950  a4:25:1b:54:9c:02 down   down    n/a
1/4      195   10GbNone         true  false    1950  a4:25:1b:54:9c:03 down   down    n/a
1/5      196   10GbNone         true  false    1950  a4:25:1b:54:9c:04 down   down    n/a
1/6      197   10GbNone         true  false    1950  a4:25:1b:54:9c:05 down   down    n/a
1/7      198   10GbNone         true  false    1950  a4:25:1b:54:9c:06 down   down    n/a
1/8      199   10GbNone         true  false    1950  a4:25:1b:54:9c:07 down   down    n/a
1/9      200   10GbNone         true  false    1950  a4:25:1b:54:9c:08 down   down    n/a
1/10     201   10GbNone         true  false    1950  a4:25:1b:54:9c:09 down   down    n/a
1/11     202   10GbNone         true  true     1950  a4:25:1b:54:9c:0a up     down    n/a
1/12     203   10GbNone         true  false    1950  a4:25:1b:54:9c:0b down   down    n/a
1/13     204   10GbNone         true  false    1950  a4:25:1b:54:9c:0c down   down    n/a
1/14     205   10GbNone         true  false    1950  a4:25:1b:54:9c:0d up     down    n/a
1/15     206   10GbNone         true  false    1950  a4:25:1b:54:9c:0e up     down    n/a
1/16     207   10GbCX           true  false    1950  a4:25:1b:54:9c:0f up     up      n/a
1/17     208   10GbNone         true  false    1950  a4:25:1b:54:9c:10 down   down    n/a
1/18     209   10GbNone         true  false    1950  a4:25:1b:54:9c:11 down   down    n/a
1/19     210   10GbNone         true  false    1950  a4:25:1b:54:9c:12 down   down    n/a
1/20     211   10GbNone         true  false    1950  a4:25:1b:54:9c:13 down   down    n/a
1/21     212   10GbNone         true  false    1950  a4:25:1b:54:9c:14 up     down    n/a
1/22     213   10GbNone         true  false    1950  a4:25:1b:54:9c:15 up     down    n/a
1/23     214   10GbNone         true  false    1950  a4:25:1b:54:9c:16 down   down    n/a
1/24     215   10GbNone         true  false    1950  a4:25:1b:54:9c:17 up     down    n/a
1/25     216   10GbNone         true  false    1950  a4:25:1b:54:9c:18 down   down    unlocked
1/26     217   10GbNone         true  false    1950  a4:25:1b:54:9c:19 down   down    unlocked
1/27     218   10GbNone         true  false    1950  a4:25:1b:54:9c:1a down   down    unlocked
1/28     219   10GbNone         true  false    1950  a4:25:1b:54:9c:1b down   down    unlocked
1/29     220   10GbNone         true  false    1950  a4:25:1b:54:9c:1c down   down    unlocked
1/30     221   10GbNone         true  false    1950  a4:25:1b:54:9c:1d down   down    unlocked
1/31     222   10GbNone         true  false    1950  a4:25:1b:54:9c:1e down   down    unlocked
1/32     223   10GbNone         true  false    1950  a4:25:1b:54:9c:1f down   down    unlocked
1/33     224   10GbNone         true  false    1950  a4:25:1b:54:9c:20 down   down    unlocked
1/34     225   10GbNone         true  false    1950  a4:25:1b:54:9c:21 down   down    unlocked
1/35     226   10GbNone         true  false    1950  a4:25:1b:54:9c:22 down   down    unlocked
1/36     227   10GbNone         true  false    1950  a4:25:1b:54:9c:23 down   down    unlocked
1/37     228   10GbNone         true  false    1950  a4:25:1b:54:9c:24 down   down    unlocked
1/38     229   10GbNone         true  false    1950  a4:25:1b:54:9c:25 down   down    unlocked
1/39     230   10GbNone         true  false    1950  a4:25:1b:54:9c:26 down   down    unlocked
1/40     231   10GbNone         true  false    1950  a4:25:1b:54:9c:27 down   down    unlocked
1/41     232   10GbNone         true  false    1950  a4:25:1b:54:9c:28 down   down    unlocked
1/42     233   10GbNone         true  false    1950  a4:25:1b:54:9c:29 down   down    unlocked
1/43     234   10GbNone         true  false    1950  a4:25:1b:54:9c:2a down   down    unlocked
1/44     235   10GbNone         true  false    1950  a4:25:1b:54:9c:2b down   down    unlocked
1/45     236   10GbNone         true  false    1950  a4:25:1b:54:9c:2c down   down    unlocked
1/46     237   10GbNone         true  false    1950  a4:25:1b:54:9c:2d down   down    unlocked
1/47     238   10GbNone         true  false    1950  a4:25:1b:54:9c:2e down   down    unlocked
1/48     239   10GbNone         true  false    1950  a4:25:1b:54:9c:2f down   down    unlocked
2/1      256   40GbNone         true  false    1950  a4:25:1b:54:9c:40 up     down    n/a
2/2      260   40GbNone         true  false    1950  a4:25:1b:54:9c:44 down   down    n/a
2/3      264   40GbNone         true  false    1950  a4:25:1b:54:9c:48 down   down    n/a
2/4      268   40GbNone         true  false    1950  a4:25:1b:54:9c:4c down   down    n/a
2/5/1    272   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:50 down   down    unlocked
2/5/2    273   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:51 down   down    unlocked
2/5/3    274   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:52 down   down    unlocked
2/5/4    275   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:53 down   down    unlocked
2/6      276   40GbNone         true  false    1950  a4:25:1b:54:9c:54 down   down    unlocked
