Use the following procedure to add the common name of the Certificate Authority.
This procedure does not apply to VSP 8600 Series.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Select System Log.
  3. Select Certificate Table tab.
  4. Select Insert.
  5. In the CaCommonName field, enter the common name of the Certificate Authority.
  6. Select Insert.
Certificate Table Field Definitions
Use the data in the following table to use the Certificate Table tab.
Name Description
CaCommonName
Specifies the Certificate Authority common name of a syslog server.
