This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB node as a boundary node to forward traffic from the UNIs to the remote-area and from the remote-area to the UNIs without requiring an established adjacency in the home area.
  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Configure the multi-area flags functionality:
    multi-area flags home-always-up
