This procedure does not apply to VSP 8600 Series.
Use this task to view IP address statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IP tab.
 - To clear IP statistics, select Clear Stats.
 - To clear IP counters, select Clear Counters.
IP Field Descriptions
Use the data in the following table to use the IP tab.
 Name  |
 Description  |
 InReceives  |
 Shows the inbound packet statistics.  |
 InHdrErrors  |
                 Shows the inbound packets with header errors statistics.  |
 InAddrErrors  |
                 Shows the inbound packets with address errors statistics.  |
 InUnknownProtos  |
                 Shows the inbound packets with unknown protocols statistics.  |
                 InDiscards  |
                 Shows the inbound packets discarded statistics.  |
| InDelivers |
                 Shows the inbound packets delivered statistics.  |
| OutRequests |
                 Shows the outbound packet requests statistics.  |
| OutDiscards |
                 Shows the outbound packets discarded statistics.  |
| OutNotRoutes |
                 Shows the outbound packets with no routes statistics.  |
| ForwDatagrams |
                 Shows the forwarded datagram packets statistics.  |
| ReasmTimeout |
                 Shows the packet reassembly timeouts statistics.  |
| ReasmReqds |
                 Shows the packet reassembly requests statistics.  |
| ReasmOKs |
                 Shows the successfully reassembled packets statistics.  |
| ReasmFails |
                 Shows the failed reassembled packets statistics.  |
| FragOKs |
                 Shows the successfully fragmented packets statistics.  |
| FragFails |
                 Shows the failed fragmented packets statistics.  |
| FragCreates |
                 Shows the fragments created statistics.  |
