Configuring a remote VTEP
Use the following procedure to configure the remote VTEP destination. The total number of VTEP remote destination IPs that you can configure is 500.
 - Click VTEP.
 - Click the Vtep tab.
 - In the Id field, assign a unique index value to this remote VTEP.
 - In the IpAddr field, enter the IP address of this remote VTEP.
 - In the Name field, assign a name to this remote VTEP.
 - Click Apply.
Vtep field descriptions
Use the data in the following table to use the Vtep tab.
 Name  |
 Description  |
 Id  |
 Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP.  |
 IpAddr  |
 Specifies an IP address that uniquely identifies this remote VTEP. Note:
The remote VTEP IP address cannot be a local, broadcast, or multicast IP address.  |
 Name  |
 Assigns a name to this remote VTEP tunnel.  |
 NextHopVrfName  |
 Displays the VRF name of the next hop to reach the remote VTEP.  |
 OvsdbConfigured  |
 Specifies if the VTEP is configured with OVSDB protocol support for VXLAN Gateway.  |
