View stat rate limit statistics to view the total dropped packets and bytes.
- In the Device Physical View, select a port.
 - Click Port.
 - Click the Stat Rate Limit tab.
 - Select one or more values.
 - Click the type of graph to create.
Stat Rate Limit Field Descriptions
Use the data in the following table to use the Stat Rate Limit tab.
 Name  |
 Description  |
 DropPktRate  |
 Indicates the drop packet rate.  |
 DropByteRate  |
 Indicates the drop byte rate.  |
 DropTotalBytes  |
 Indicates the total bytes dropped.  |
 DropTotalPkts  |
 Indicates the total packets dropped.  |
