Create a virtual link if the switch does not connect directly to the backbone. The switch can create automatic virtual links or you can perform this procedure to create virtual links manually. Manual virtual links conserve resources and provide specific control over virtual link placement in your OSPFv3 configuration.
The router must be an ABR to create a virtual router interface.
                    Change the VRF instance as required to configure OSPFv3 on a specific VRF instance.
Non-default VRFs do not support the configuration of the following parameters:-
OSPFv3 interfaces over IPv6 tunnels
IPSec on OSPFv3 virtual link interfaces
Virtual linking is similar to backup redundancy. The switch creates a virtual link for vital traffic paths in your OSPFv3 configuration if traffic is interrupted, such as when an interface cable that provides a connection to the backbone (either directly or indirectly) is disconnected from the switch. Automatic virtual linking ensures that a link is created by using another switch.
OSPF routes cannot be learned through an ABR unless it connects to the backbone directly or through a virtual link.
Virtual If field descriptions
Use the data in the following table to use the Virtual If tab.
Name  | Description  |
AreaId  | Specifies the ID for the transit area that the virtual link traverses. Do not use 0.0.0.0.  |
Neighbor  | Specifies the router ID of the virtual neighbor.  |
TransitDelay  | Specifies the estimated number of seconds to transmit a link-state update packet over this interface. The default is 1 second.  |
RetransInterval  | Specifies the number of seconds between link-state advertisement retransmissions for adjacencies that belong to this interface. This value also applies to the retransmissions of database description and link-state request packets. The default is 5 seconds.  |
HelloInterval  | Specifies the number of seconds between hello packets that the router sends on this interface. Configure the same value on the virtual neighbor. The default is 10 seconds.  |
RtrDeadInterval  | Specifies the number of seconds after which the neighbor declares the router down if it does not receive hello packets. Configure this value as a multiple of the hello interval. You must configure the same value on the virtual neighbor. The default is 60 seconds.  |
State  | Shows the state of the virtual interface: either down or pointToPoint.  |
Events  | Shows the number of state changes or error events on the virtual link.  |
LinkScopeLsaCount  | Shows the number of link-scope LSAs in the LSDB for the virtual link.  |
LinkLsaCksumSum  | Shows the sum of the checksums for the link-scope LSAs in the LSDB. Use the sum to determine if a change in the LSDB occurs, and to compare the LSDBs of the two routers.  |
