Filter SPB routes to filter which (S,G,RP) entries sent out to all MSDP peers. This procedure applies only to the rendezvous point (RP) that originates the MSDP SA messages and not the intermediate MSDP peers that forward the received SA messages.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp redistribute
Switch:1(config)#ip msdp redistribute route-policy helloworld
Switch:1(config)#ip msdp apply redistribute
Variable definitions
The following table defines parameters for the clear ip redistribute command.
 Variable  |
 Value  |
 WORD<1-64>  |
 Specifies the route policy name.  |
