Apply an MKA profile to the port.
Before you enable MKA on a port, the port must be a member of a connectivity association.
Switch:1#enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/3 Switch:1(config-if)#macsec mka enable
The following table defines parameters for the macsec mka enable command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
