BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
BFD supports internal Border Gateway Protocol (iBGP) and external Border Gateway Protocol (eBGP) on IPv4 interfaces. You configure BFD on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip bgp. BFD does not support BGPv6 for VRF on IPv6 interfaces.
Enabling BFD at the BGP application level does not establish a BFD session. To establish a BFD session, you must enable BFD globally and at the interface level.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router bgp Switch:1(router-bgp)#neighbor 192.0.2.15 fall-over bfd
The following table defines parameters for the neighbor command.
                             Variable  |
                             Value  |
                             WORD<0-1536>  |
                             Specifies the peer IP address or the peer group name.  |
