Trigger a Loopback Test
Use this procedure to trigger a loopback test.
The LBM packet is often compared to ping. An MEP transmits the loopback message to an intermediate or endpoint within a domain for the purpose of fault verification. This can be used to check the ability of the network to forward different sized frames.
On the source and destination nodes, you must configure a CFM MD, MA, and MEP.
Enable the MEP.
Assign a nodal MEP to the B-VLAN.
 - Click CFM.
 - Click the LBM tab.
 - Configure the loopback test properties as required.
 - Click Apply.
 - To trigger the loopback test, double-click in the Status field, select transmit.
 - Click Apply.
 - To update the loopback test, click the Refresh button.
LBM Field Descriptions
Use the data in the following table to use the LBM tab.
 Name  |
 Description  |
 DomainIndex  |
 Specifies the MD index value.  |
 AssociationIndex  |
 Specifies the MA index value.  |
 Index  |
 Specifies the Maintenance Endpoint index value.  |
 DomainName  |
 Specifies the MD name.  |
 AssociationName  |
 Specifies the MA name.  |
 DestMacAddress  |
 Specifies the remote MAC address to reach the MEP/MIP.  |
 Messages  |
 Specifies the number of loopback messages to be transmitted. The default is 1.  |
 VlanPriority  |
 Specifies the priority. The default is 7.  |
 SeqNumber  |
 Specifies the transaction identifier/sequence number of the first loopback message (to be) sent. The default is 0.  |
 ResultOk  |
 Indicates the result of the operation:
 The default is true.  |
 Status  |
 Indicates the status of the transmit loopback service:
 The default is ready.  |
 Result  |
 Displays the LBM result.  |
 TimeoutInt  |
 Specifies the timeout interval in seconds. The default value is 3 seconds.  |
 InterFrameInt  |
 Specifies the interval between LBM frames with a range of (0..1000) msecs and a default value of 500 msecs. The value of 0 msecs indicates to send the frames as fast as possible. The default is 500.  |
 TestPattern  |
 Specifies the testfill pattern:
 A cyclic redundancy check is a code that detects errors. The default value is allZero.  |
 DataSize  |
 Specifies the data type-length-value (TLV) size. The default is 0.  |
 FrameSize  |
 Specifies the frame-size. The default is 0.  |
 Sourcemode  |
 Specifies the source mode of the transmit loopback service:
 The default is nodal.  |
