Use the following procedure to display the statistics of the number of packets mirrored into I-SID on the mirroring BEB.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# show isid-mirroring stats monitor-isid-offset 1 ================================== Mirror Statistics Info ================================== ISID ISID_OFFSET PACKETS ---------------------------------- 16776000 1 100 ----------------------------------
The following table defines parameters for the show isid-mirroring stats command.
 Variable  |
 Value  |
 monitor-isid-offset WORD<1–1024>  |
 Specifies the offset ID mapped to monitor the I-SID. The offset ID ranges from 1 to 1000.  |
