This procedure only applies to the VSP 7400 Series.
Perform this procedure to apply the Multi-area SPB layer 2 multicast redistribution that you configure in the home area.
 - Select MultiArea
 - Select the L2 MC Apply Home tab.
 - In the McastApply field, select apply.
L2 MC Apply Home Field Descriptions
Use data in the following table to use the L2 MC Apply Home tab.
| Name | Description |
                                 McastApply  |
                                 Applies or disables the Multi-area SPB layer 2 multicast redistribution in the home area.
