Reset the platform to reload system parameters from the most recently saved
                        configuration file. Use the following procedure to reset the device using
                        EDM.
                In the navigation pane, expand
                                Select
                                                Chassis.
                                Select the
                                                System tab.
                                From ActionGroup1, select saveRuntimeConfig.
                                Select Apply.
                                From ActionGroup4, select softReset .
                                Select
                                                Apply.
