View IPv6 ICMP statistics on an interface for ICMP messages sent over a particular interface.
  1. To enter User EXEC mode, log on to the switch.
  2. View IPv6 ICMP statistics:
    show ipv6 interface icmpstatistics [gigabitethernet <slot/port[/sub-port]> | loopback <1–256> | mgmtethernet mgmt|tunnel <1-2000> | vlan <1-4059>] [vrf WORD<1–16>] [vrfids WORD<0–512>]
    The mgmtethernet mgmt parameter is only supported on VSP 8600 Series.
View ICMP statistics:
Switch:1>show ipv6 interface icmpstatistics
                                   Icmp Stats
Icmp stats for IfIndex = 192
IcmpInMsgs: 0
IcmpInErrors: 0
IcmpInDestUnreachs : 0
IcmpInAdminProhibs : 0
IcmpInTimeExcds : 0
IcmpInParmProblems : 0
IcmpInPktTooBigs : 0
IcmpInEchos : 0
IcmpInEchoReplies : 0
IcmpInRouterSolicits : 0
IcmpInRouterAdverts : 0
InNeighborSolicits : 0
InNbrAdverts : 0
IcmpInRedirects : 0
IcmpInGroupMembQueries : 0
IcmpInGroupMembResponses : 0
Use the data in the following table to use the show ipv6 interface icmpstatistics command
Variable
Value
<1-4059>
Shows ICMP statistics for the specific interface index. If you do not specify an interface index, the command output includes all IPv6 ICMP interfaces.
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
gigabitethernet {slot/port[/sub-port]}
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
loopback <1–256>>
Identifies a loopback interface.
mgmtethernet mgmt
Note:
Exception: only supported on VSP 8600 Series.
Identifies the management interface. This parameter only applies to hardware with a dedicated, physical management interface.
tunnel <1-2000>
Identifies a 6in4 tunnel ID.
vrf WORD<1–16>
Specifies the VRF name.
vrfids WORD<0–512>
Specifies the VRF ID.
