This procedure does not apply to XA1400 Series or VSP 8600 Series.
View fan information to monitor the alarm status of the cooling ports in the chassis.
  1. To enter User EXEC mode, log on to the switch.
  2. Display fan information:
    show sys-info fan
View fan information:
Switch:1>show sys-info fan
Tray      Unit      Oper Speed      Oper Speed (Rpm) Airflow Type      Status
1         1         LOW             5782             F2B               OK
1         2         LOW             3366             F2B               OK
