You must globally enable OSPF.
The OSPF area must already exist.
Enable Open Shortest Path First (OSPF) on a CLIP interface so that it can participate in OSPF routing.
Circuitless OSPF field descriptions
Use the data in the following table to use the Circuitless OSPF tab.
Name  | Description  |
Enable  | Enables OSPF on the CLIP interface.  |
AreaId  | Specifies the OSPF area ID.  |
