Enable the SNMP agent process to generate authentication-failure traps.
 - Click General.
 - Click the Error tab.
 - Select AuthenticationTraps.
 - Click Apply.
Error Field Descriptions
Use the data in the following table to use the Error tab.
 Name  |
 Description  |
 AuthenticationTraps  |
 Enables or disables the sending of traps after an error occurs. The default is disabled.  |
 LastErrorCode  |
 Specifies the last reported error code.  |
 LastErrorSeverity  |
 Specifies the last reported error severity: 0= Informative Information 1= Warning Condition 2= Error Condition 3= Manufacturing Information 4= Fatal Condition  |
