Configure a redistribute entry to announce routes of a certain source protocol type into the RIPng domain, for example, static, RIP, or direct. Use a route policy to control the redistribution of routes.
Enable RIP globally.
Configure a route policy.
- In the navigation tree, expand the following folders: Configuration > IPv6.
 - Click IPv6 RIPng.
 - Click the Redistribute tab.
 - Double-click the value in the Enable column that corresponds with the source protocol type you want to enable or disable.
 - Select enable or disable from the list.
 - Click Apply.
Redistribute field descriptions
Use the data in the following table to use the Redistribute tab.
 Name  |
 Description  |
 DstVrfiId  |
 Specifies the destination VRF ID used in the redistribution.  |
 Protocol  |
 Specifies the dynamic routing protocol that receives the external routing information.  |
 SrcVrfId  |
 Specifies the source VRF ID used in the redistribution.  |
 RouteSource  |
 Specifies the route source protocol for the redistribution entry.  |
 Enable  |
 Enables (or disables) a RIPng redistribute entry for a specified source type.  |
