The following table defines parameters for the ssh key-exchange-method command.
| Variable | Value |
                             [diffie-hellman-group14-sha1][diffie-hellman-group-exchange-sha256] Note:
                        Exception: diffie-hellman-group-exchange-sha256 is not supported on VSP 8600 Series.  |
                             Configures the key-exchange method. Select a key-exchange method from
                                one of the following:
