View information about IGMP snoop to see the current configuration.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
- In the navigation pane, expand the following folders: .
 - Click IGMP.
 - Click the Snoop tab.
Snoop field descriptions
Use the data in the following table to use the Snoop tab.
 Name  |
 Description  |
 Interface  |
 Shows the VLAN ID for the VLAN.  |
 SnoopEnable  |
 Shows the status of IGMP snoop. IGMP snoop works only if a multicast router exists in the VLAN.  |
 SsmSnoopEnable  |
 Shows the status of SSM snoop.  |
 ProxySnoopEnable  |
 Indicates whether the IGMP report proxy feature is enabled. If you enable this feature, the switch forwards reports from hosts to the multicast router once for each group for each query interval, or after new group information is available. If you disable this feature, the switch forwards all reports from different hosts to multicast routers, and can forward more than one group report for the same multicast group for each query interval. The default is enabled.  |
 FastLeaveEnable  |
 Shows the status of fast leave for this port.  |
 FastLeavePortMembers  |
 Lists ports that are enabled for fast leave.  |
 SnoopMRouterPorts  |
 Shows the configuration of ports as multicast router ports. Such ports attach to a multicast router, and forward multicast data and group reports to the router. Important:
Configure this variable only if you use multiple multicast routers that do not attach to one another, but attach to the VLAN (technically, an invalid configuration). If multicast routers use a route between them (the valid configuration) and you configure this variable, a multicast loop forms.  |
 SnoopActiveMRouterPorts  |
 Shows the active multicast router ports. Active multicast router ports are ports that directly attach to a multicast router. These ports include the querier port and all ports in the forwarding state that you configure as well as those that were dynamically learned through receiving queries.  |
 SnoopMRouterExpiration  |
 Indicates the time that remains before the multicast router ages out. If the switch does not receive queries before this time expires, it flushes out all group memberships known to the VLAN. The query maximum response interval (obtained from the queries received) is used as the timer resolution.  |
