Use this procedure to configure the device subject parameters to identify the device, such as the name, Email ID, company, department, location, and subject name.
Configuring subject parameters:
Switch:1>enable Switch:1#configure terminal Switch:1(config)# certificate subject common-name 822-pki e-mail client1@extemenetworks.com unit Engineering organization ExtremeNetworks locality Salem province Massachusetts country US subject-name 822
View the configuration.
Switch:1>show certificate subject Subject Name : 822 Common Name : 822-pki Email Address : client1@extemenetworks.com Organizational Unit : Engineering Organization : ExtremeNetworks Locality : Salem Province : Massachusetts Country : US Subject Name : 823 Common Name : 823-pki Email Address : client1@extemenetworks.com Organizational Unit : Engineering Organization : ExtremeNetworks Locality : Salem Province : Massachusetts Country : US Subject Name : Global Common Name : 821 Email Address : client1@extemenetworks.com Organizational Unit : Engineering Organization : ExtremeNetworks Locality : Salem Province : Massachusetts Country : US
The following table defines parameters for the certificate subject command.
                                 Variable  |
                                 Value  |
                                 common-name WORD<0–64>  |
                                 Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 country WORD<2-2>  |
                                 Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 e-mail WORD<0-254>  |
                                 Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 locality WORD<0-128>  |
                                 Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 organization WORD<0-64>  |
                                 Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 province WORD<0-128>  |
                                 Specifies the state or province of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 subject-name WORD<1-45> Note:
                            Exception: Not supported on VSP 8600 Series.  |
                                 Specifies the Subject Identity Label to be used in local digital certificate request. You can configure up to 10 subject DN identities. If a subject name is not specified, the default subject name is Global.  |
                                 unit WORD<0-64>  |
                                 Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority.  |
