Create a community to use in forming a relationship between an SNMP agent and one or more SNMP managers. You require SNMP community strings to access the system using an SNMP-based management software.
In the following example, the community name is anewcommunity, the index is third, and the secname is readview. There is no group specified because this is a default public/read only group.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#snmp-server community anewcommunity index third secname readview
The following table defines parameters for the snmp-server community command.
 Variable  |
 Value  |
 community WORD<1-32>  |
 Specifies a community string. The range is 1–32 characters.  |
 group WORD<1-32>  |
 Specifies the group name. The range is 1–32 characters.  |
 index WORD<1-32>  |
 Specifies the unique index value of a row in this table. The range is 1–32 characters.  |
 secname WORD<1-32>  |
 Maps the community string to the security name in the VACM Group Member Table. The range is 1-32 characters.  |
