Perform this procedure to filter for specific LAN traffic packets.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click Eth.
 - Click the Ethernet Type tab.
 - Click Insert.
 - Specify the operation type.
 - In the TypeList box, type the Ethernet types.
 - Click Insert.
Ethernet Type field descriptions
Use the data in the following table to use the Ethernet Type tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 TypeOper  |
 The eq parameter specifies an operator for a field match condition: equal to.  |
 TypeList  |
 Specifies the Ethernet type. Entries include: 0 to 0xffff or ip, arp, ipx802.3, ipx802.2, ipxSnap, ipxEthernet2, appleTalk, appleTalk-ARP, sna802.2, snaEthernet2, netBios, xns, vines, ipv6, rarp, PPPoE-discovery, and PPPoE-session. Note:
Ethernet ACE filter configured with Ethernet Type ipx802.3 does not match the packet with format destination MAC address, source MAC address, length, 0xFFFF, payload and FCS. Ethernet ACE filter configured with Ethernet Type ipx802.2 does not match the packet with format destination MAC address, source MAC address, length, 0xE0E0, payload and FCS.  |
