You can configure IPv6 VRRP to preempt the existing router. If a new VRRP router is added to the network with a higher priority than the existing routers, then the new router becomes the master. If preempt-mode is disabled, then the new router does not become a master, it transitions to master only when the current master is down. By default, preempt-mode is enabled.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface gigabitethernet 1/2
Enabling IPv6 VRRP preempt-mode for interface 1/2
Switch:1(config-if)# ipv6 vrrp 1 preempt-mode enable
Variable definitions
Use the data in the following table to use the ipv6 vrrp <vrid> command.
 Variable  |
 Value  |
 enable  |
 Enables preempt-mode for VRRPv3 for IPv6.  |
 vrid <1–255>  |
 Specifies the virtual router ID.  |
