Use the chassis shortcut menu
Perform the following procedure to display the chassis shortcut menu.
- In the Device Physical View, select the chassis.
 - Right-click the chassis.
Chassis shortcut menu field descriptions
Use the data in the following table to use the Chassis shortcut menu.
 Name  |
 Description  |
 Edit  |
 Edits chassis parameters.  |
 Graph  |
 Graphs chassis statistics.  |
 Refresh Status  |
 Refreshes the status of the chassis and MDAs.  |
 Refresh Port Tooltips  |
 Refreshes the port tooltip data of the system. The port tooltip data contains the following variables: Slot/Port, PortName, and PortOperSpeed.  |
