Configure the remote host address for log transfer. The system transfers the current log file to a remote host after the log file size reaches the maximum size.
The IP address you configure for the remote host must be reachable at the time of configuration.
Switch:1(config)# logging transferFile 1 address 192.0.2.10
The following table defines parameters for the logging transferFile command.
 Variable  |
 Value  |
 1–10  |
 Specifies the file ID to transfer.  |
 address {A.B.C.D}  |
 Specifies the IP address of the host to which to transfer the log file. The remote host must be reachable or the configuration fails.  |
 filename-prefix WORD<0–200>  |
 Specifies the name of the file on the remote host. If you do not configure a name, the current log file name is the default.  |
