Configuring SLPP globally
Enable the Simple Loop Prevention Protocol (SLPP) to detect a loop and automatically stop it.
 - Click SLPP.
 - Click the Global tab.
 - Select GlobalEnable.
 - In the TransmissionInterval box, type a value for the time interval for loop detection.
 - Click Apply.
Global field descriptions
Use the data in the following table to use the Global tab.
 Name  |
 Description  |
 GlobalEnable  |
 Activates or disables SLPP globally. The default is disabled.  |
 TransmissionInterval  |
 Configures the interval for which loop detection occurs. The interval is expressed in milliseconds in a range from 500–5000. The default value is 500.  |
Job aid
The following table provides the SLPP values.
                             Enable SLPP  |
                             Setting  |
                             Access SMLT  |
                             Yes  |
                             Core SMLT  |
                             No  |
                             Primary switch  |
                             Packet Rx threshold  |
                             5  |
                             Transmission interval  |
                             500 milliseconds (ms) (default)  |
                             Secondary switch  |
                             50  |
                             500 ms (default)  |
