Create an IP VPN instance to advertise IP routes from one VRF to another across a Shortest Path Bridging MAC (SPBM) network.
The VRF must exist.
From Global Configuration mode, log on to Router VRF Configuration mode:
Switch:1(config)# router vrf red
Create the IP VPN instance:
Switch:1(router-vrf)# ipvpn
Enable IP VPN:
Switch:1(router-vrf)# i-sid 100
Enable IP VPN:
Switch:1(router-vrf)#ipvpn enable
                                        IPv4 IPVPN
VRF Name            VRF ID   IPv4 IPVPN   IPv6 IPVPN   I-SID        I-SID Name
red                 1        enabled      disabled     100          ISID-1
1 out of 1 Total active IPv4 L3 VSN displayed, including 0 active IPv6 L3 VSN.
          Variable definitions
Use the data in the following table to use the show ip ipvpn command.
 Variable  |
 Value  |
 vrf WORD<1–16>  |
 Specifies the VRF name.  |
 vrfids WORD<0–512>  |
 Specifies the VRF ID.  |
Use the data in the following table to use the i-sid command.
 Variable  |
 Value  |
 i-sid <0–16777215>  |
 Assigns an I-SID to the VRF to configure. Use the no or default option to remove the I-SID to VRF allocation for this VRF.  |
