Use the following procedure to configure the format of the RADIUS password when authenticating NEAP MAC addresses using RADIUS.
The following table defines parameters for the eapol multihost non-eap-pwd-fmt command.
                                                   Variable  |
                                                   Value  |
                                                   ip-addr  |
                                                   Management ip-address of the switch.  |
                                                   key WORD<1-32>  |
                                                   Key value used for non-eap password format.  |
                                                   mac-addr  |
                                                   Mac-Address of the client.  |
                                                   padding  |
                                                   Includes a dot in the RADIUS password for every missing parameter.  |
                                                   port-number  |
                                                   Index of the port on which MAC is received.  |
To derive the port number for an interface, use the command show interfaces gigabit [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}] .
If you configure interface 1/6 on the product, to derive the port-number for this interface, use the command show interfaces gigabitEthernet 1/6. From this command, you can ascertain that port number used in the NEAP password is 197.
Switch:1(config)# show interfaces gigabitEthernet 1/6
                                      Port Interface
PORT                            LINK  PORT           PHYSICAL          STATUS
NUM      INDEX DESCRIPTION      TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE
1/6      197   1000BaseTX       true  false    1950  f8:15:47:e1:dd:05 up     up
