Perform this procedure to configure the destination IP address for the IPsec tunnel on a specific IS-IS logical interface on the switch.
Product Notice: This procedure only applies to XA1400 Series switches.
  1. Enter Logical IS-IS Interface Configuration mode:
    enable
    configure terminal
    logical-intf isis <1–255>
  2. Configure destination IP address for IPsec tunnel:
    ipsec tunnel-dest-ip {A.B.C.D}
Configuring destination IP address for IPsec tunnel.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#logical-intf isis 1
Switch:1(config-isis-1-192.0.2.25)ipsec tunnel-dest-ip 192.0.2.30
The following table defines the variable for ipsec tunnel-dest-ip command.
Variable Value
{A.B.C.D}
Specifies destination IP address for the IPsec tunnel on a specific IS-IS logical interface.
Note:
When you configure the destination IP address for the IPsec tunnel, IKE protocol uses UDP port 500. However, if IPsec NAT-T is detected, IKE protocol uses UDP port 4500 instead.
