Associating ports with an ACL
Associate ports with an ACL to apply filters to port traffic.
A port can be part of two different ACLs of different types: IPv6 and non-IPv6.
The ACL exists.
Variable definitions
Use the data in the following table to use the filter acl port command.
 Variable  |
 Value  |
 <acl-id>  |
 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
